collapseBuild Queue
No builds in the queue.
   S   WNameLast SuccessLast FailureLast Duration
Unstable92%
WDescription%
Test Result: 5 tests failing out of a total of 63 tests.92
Build stability: No recent builds failed.100
Binding Factory 7 yr 9 mo - #67 8 yr 1 mo - #589 min 42 sec
Success100%
WDescription%
Demo Parent 8 yr 3 mo - #126N/A46 sec
Failed80%
WDescription%
Build stability: 1 out of the last 5 builds failed.80
Test Result: 17 tests failing out of a total of 379 tests.95
FraSCAti 6 yr 8 mo - #545 6 yr 8 mo - #5461 hr 32 min
Unstable80%
WDescription%
Test Result: 5 tests failing out of a total of 65 tests.92
FraSCAti examples 7 yr 11 mo - #192 8 yr 1 mo - #18923 min
Failed0%
WDescription%
Build stability: All recent builds failed.0
FraSCAti ModelN/A 8 yr 10 mo - #317 sec
Success100%
WDescription%
FraSCAti parent module 6 yr 8 mo - #396 6 yr 9 mo - #3911 min 48 sec
Disabled100%FraSCAti-SonarN/AN/AN/A
Success100%
WDescription%
Test Result: 0 tests failing out of a total of 17 tests.100
Juliac 6 yr 9 mo - #100 6 yr 11 mo - #926 min 53 sec
Failed0%
WDescription%
Tinfi 8 yr 7 mo - #51 6 yr 8 mo - #934 min 45 sec
Icon:  S M L
